SEQ-4a Post Screen a case get Error 400 Bad Request
Hi, Try to implement Screen a case like sample SEQ-4a. Post request get Error 400 Bad Request.
I use the postman default group id in the pilot environment.
Please check the source code as below, for the function of “Save a simple case”
procedure TForm2.btSaveasimplecaseClick(Sender: TObject);
var
response : string;
RequestBody : TstringStream;
tt : TBytes;
dataToSign, strdatetime : string;
thedate : tdatetime;
const
strbody='{ "entityType": "INDIVIDUAL", "groupId":"418f28a7-b9c9-4ae4-8530-819c61b1ca6c","providerTypes": ["WATCHLIST"], "name": "John Doe"}';
strbaseurl='https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases';
begin
thedate:=now-(13/24); // get server time , the offset of the time different is 13 hours
strdatetime:= formatdatetime('ddd, dd mmm yyyy hh:mm:ss "GMT"',thedate);
edtdate.Text:=strdatetime; // display purpose – date string
dataToSign:= '(request-target): post /v1/cases'+#10 +'host: rms-world-check-one-api-pilot.thomsonreuters.com' +#10+'date: '+strdatetime+#10+'content-type: application/json'+#10+'content-length: '+
inttostr(length(strbody))+#10+strbody;
msignstring.Lines.Text:=datatosign; // Sign string -- display purpose
tt:=System.Hash.THashSHA2.GetHMACasBytes(dataToSign,APIsecret,SHA256);
edtsignatures.text:=EncodeBase64(tt,length(tt)); // signature string - display purpose
edtauth.Text:='Signature keyId="a4364e62-e58b-4b64-9c71-faead5417557",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="'+edtsignatures.text+'"'; // authorization string
edit1.Text:=inttostr(length(strbody)); // content -length
RequestBody := TStringStream.Create(strbody, TEncoding.UTF8);
RequestBody.Position := 0;
try
IdHTTP1.Request.CustomHeaders.Clear;
IdHTTP1.Request.Method:=Id_HTTPMethodPost;
IdHTTP1.Request.ContentType := 'application/json';
IdHTTP1.Request.CustomHeaders.AddValue('cache-control', 'no-cache');
IdHTTP1.Request.CustomHeaders.AddValue('authorization',edtauth.Text);
IdHTTP1.Request.CustomHeaders.AddValue('date', strdatetime);
IdHTTP1.Request.CustomHeaders.AddValue('content-type', 'application/json');
IdHTTP1.Request.CustomHeaders.AddValue('content-length', inttostr(length(strbody)));
try
IdHTTP1.Post(strbaseurl, RequestBody);
except
on e:EIdHTTPProtocolException do
begin
showmessage(e.ErrorMessage+' .. '+ e.Message );
end;
on e:exception do
showmessage(e.Message);
end;
memo1.Lines.text:=IdHTTP1.ResponseText;
finally
RequestBody.Free;
end;
end;
// --------------------- end of code ---------------
Sign string:
date: Mon, 09 Jan 2017 23:38:56 GMT
content-length: 130
Signature:
QldTAT5loM20vBrFMBZg1ErrnYnrVtPcx+ZpxQKjkqo=
Authorization:
Signature keyId="a4364e62-e58b-4b64-9c71-faead5417557",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="QldTAT5loM20vBrFMBZg1ErrnYnrVtPcx+ZpxQKjkqo="
Date:
Sun, 08 Jan 2017 21:52:47 GMT
Content Length:
130
Response:
HTTP/1.1 400 Bad Request
Any ideal? Please help.
Thanks.
John
world-checkworld-check-one
Hi, i have found the problem and got this issue resolved. Basically it is the the HTTP component bug does not stream string parameters in order. Also there is another reasons cause the body string not compatible with the REST server. Thanks a lot for the help. John
3.1k 16 7 7
Hi @information
We do not support IDE environments. However If your GET requests succeed, then the body of your POST request is not formed properly. Perhaps try not encoding the string, first.
Brian
ddfdii,
Thanks Brian for the reply. I will try this.
3.1k 16 7 7
