How to set time range for Time Series request on Web SDK?
Is it possible to set a time range for the time series request? I saw from the jet-plugin-timeseries.js source code that there are "to" & "from" params in the request, but it is not working.
Is there any corresponding param or a guideline/whitepaper for JET time series plugin? I can't find much details on time series example except "Getting started" on the demo page....
eikontime-serieseikon-app-studioparameters
4.6k 26 7 22
You need to set the timeframe using a correct date time format, for instance:
"from": "2016-02-23T00:00:00.000",
"to": "2017-01-03T00:00:00.000",
from and to fields use date-time format. The sample request for JET time series is something like
{ "ric": "IBM.N", "timeZone": "Instrument", "intervalType":"Weekly", "intervalLength": 1, "adjustedPrice": true, "from": "2010-01-01T00:00:00Z", "to":"2012-01-01T00:00:00Z" }
You can find JET time series request schema in this doc.
https://thehub.thomsonreuters.com/docs/DOC-1586377
Hope it answers your question.
