Can RFA API Java8.0 use JDK1.6 development environment?
client only have JDK1.6 now, can client have a try , or there is no way to use JDK1.6. Client aware the potential risk taken by using JDK1.6.
treprfarfa-apijava
1.9k 6 9 16
@jessie.lin
No, you can't. If you try to run the RFA Java 8.0 library with JDK/JRE 1.6, you'll encounter java.lang.UnsupportedClassVersionError: <an application class name> : Unsupported major.minor version 51.0.
Note: major.minor version 51.0 means that the library was compiled with Java 7.
Actually, RFA Java requires JDK/JRE 7 (or higher) since version 7.4.
Hope this helps.
