Dex2 Interim Data
Am trying to access interim data using Dex2 but it keeps returning annual data.
I've copied the request parameters from the excel fundamentals template but that doesn't seem to work.
Here is what I'm trying to use:
.RequestParam = "reportingstate:rsdt scale=6 Sdate=FI-10 Edate=FI0 Frq=FI"
The data that is return brings through the right number of interim periods, but the data in the fields is the annual data, and the TR.InterimNumber is 0 for each period.
eikoneikon-com-apifundamentals
@radek
Please be informed that a reply has been verified as correct in answering the question, and has been marked as such.
Thanks,
AHS
Hi @radek,
It appears that you've missed Period=FI0 when you copied request parameters from the Excel template. Without this Period takes the default value of FY0, and data from annual report is returned. Try
.RequestParam = "Period=FI0 reportingstate:rsdt scale=6 Sdate=FI-10 Edate=FI0 Frq=FI"
4.6k 26 7 22
@radek would it be possible for you to share the code sample? your dex2 manager object creation routine might not be correct.
